I've dug up half my front driveway and filled skip 1, another skip to go.
The services to the property are not very far down from the surface, the (plastic) water is around 30cm, electricity and gas (iron pipes) around 40cm. I've done my old drive before and they were deeper than this!
You may question why I have dug to 40cm when you need 25-30cm - it's because the original drive has just been built over and the current level is too high (at the damp course level) and I wanted to lower it by approx 10cm
So what to do, don't want to damage anything (especially gas) with the type 1 and compacting.
Would it be bedding the pipes in a few inches of sharp sand, then covering with more sand, type 1 on top, or is there something else I should use or do? It's a heavy clay soil if it matters.
Many thanks
Many thanks
