digi manometer
8 Sep 2008
Hampshire
Good morning to you all,
I am not sure if this is the right forum section for this question ,but here goes...
I am thinking of buying a digi manometer,and am wondering which one(s) you guys use or have used, and your thoughts on them.
Obviously as this is a digital piece of equipment it needs to be calibrated to keep its accuracy.How often does this need to be done, and what is the cost of this?
Thanks in advance
Linkyplumb
Why would you want one? Buy a decent analogue one, like a Regin Premier, and there's no need at all to get a digital one. I would expect that most digi ones require annual calibration in the same way that FGA's do. I've never heard of a trad sight gauge needing calibration at all...
i have the premier & it is the db.
but today i needed a reading of -3.14 mb the only way to get that is digital.
Ah, negative pressures, now that's a different kettle of fish I agree.
Incidentally, at the risk of going off-topic, where do you get the fluid for your regin from? How much is it? Obviously not blowing it out is the preferable option, but these things do 'appen :oops:
i've bought probably 2 bottles in the last 4 years from partscenter, stupid price probably at a guess £6-8 for a dribble. but if there is a risk of blowing the gauge i also have a water manometer (with glass tubes) not carp regin one, if necessary.
i'm wondering how many newly qualified engineers know that you can test pressure with a rubber tube, milk bottle & tape measure.
I used to have a very tiny digi manometer from testo about 30 mm diameter until it was stolen by a builder. I bought it to take on the bus.
They then replaced it with a much larger heart shaped unit but I think they may have discontinued that as I did not see it on their site.
Tony
