digital manometers
due to calibration costs you might as well buy a cheap one like the one you mention.i use a regin digiman regx30,approx £100.00 from parts center.works well.
make sure you get one which has a strong magnet on the back very handy to attach to boilers and gas meters.digiman has magnet.
Remember to carry your water guage at all times in case electronic unit goes wrong,it happens.
if you do a lot of testing at the gas meter this 10mm socket driver makes it easyier to remove pressure nipples.
www.uktools.com part number kk167m-10
part number kk167m-8
10mm for gas meters..8mm for some boiler gas valves.
the above meter and the 2 socket drivers save me lots of time espically when i put blue tac inside the 10mm one to hold the nipple in place also acts as a depth stop.
cant find any links to the Regin digital, any links you can give?
I got a testo one for about 80 plus vat, its tiny so fits in the tool case lubberly it do :)
and its differential
I'd say make sure it reads to 0.01mbar, at least below 20mBar which is quite common. Makes it really easy an quick to see leaks.
Mine (APM140) does different units, which I don't use, but also it does MAX/MIN. Suddenly realised how useful that is:
You can't quite ever set to 20.00 mBar for a drop test, so get close and press max/min. Then press it again after the 2 mins. Lo an behold it holds both values, say 19.91mbar and 17.83mbar as they are the max and the min. Saves the grey cells. Usually I do something else for the 2 mins and forget...
I use a long hose so haven't missed a magnet - you can stick it anywhere. Also the backlight is useful, don't know if they all have one. Mine's Water Resistant - it gets wet in the rain!
And try BES.
Your testo is probably the heart shaped one!
I had a much smaller round one about 30 mm diameter which I bought specifically for service/repairs when I went to Central London on PT.
It only had one decimal place so it was not suitable for setting up the latest premix boilers but it was fine for normal fault finding.
It was stolen by a builder but the current Testo is much larger and I have not replaced it.
I have a two decimal point manometer in my Kane 400 FGA.
Tony
my test is indeed heart shaped tony of the all seeing eye
I like it, but must say that I do have my faithfull u guage to hand at all times
corgiman said:
but must say that I do have my faithfull "u" guage to hand at all times
In case the CORGI Inspector jumps out from behind the Shepherd's Bush, do you have a recent Calibration Certificate* for the "U" gauge ???
Tony
* Calibration Standards traceable to the National Physics Laboratory!
Tony
dam right I do, I am such a brown nose when it comes to corgi inspectors ;)
I have my u guage calibration cert, all written in red crayon, coloured in and everything :)
the TESTO's resolution is stated at 0.00hpa is that 2 decimal places for mbar as well?
Right i'm going to buy the TESTO - but can someone tell me the re-calabration costs and if it is resolution is 2 decimal places?
cheers ppl
can the testo be used for soundness tests, why is it marketed as a pressure gauge and not a digital manometer as well?
can someone tell me again that it can be used as a single input device.
