Hi all,
I'm looking into installing a pumped digital mixer shower and quite like the look of the Aqualisa Quartz Digital Pumped Thermostatic Exposed Shower. I've read through the installation instructions and the diagram (see attached image) seems to suggest that the hot water supply is simply tee'd off the existing outlet from the hot water cylinder. Having looked through some of the previous posts I can see most on here recommend using an Essex or Surrey flange when a pump is involved. I am curious why there is no mention of this in the installation instructions, is there a reason in this case why just tee'ing off the existing outlet is ok?
