Hello,
I have just recently replaced and old tired looking room stat which although was working correctly, it looked unsightly!
The new Room stat is a Sunvic digital stat, http://www.sunvic.co.uk/tlx7501rt.html , which is definately fitted correctly. However it is not performing as desired. If the stat is say adjusted to 19 degrees it will get quite warm and in some cases uncomfortable, the room will then drop to a cold uncomfortable temperature before it calls for heat again. So if I set it a 20 the temperature of the house gets unbearable but again it gets quite cold before it calls for heat, and setting it to 18 is just too cool.
The thermostat can only be set in 1 degree steps (5 - 35 degrees)
The system is an open vented fully pumped central hating system and all pumps and valves are oprating correctly.
So have any one have any ideas?
Lee
Lee
