Help! I have a long integral garage which at some time in the past has been split into a garage and workshop buy a 9" cavity wall. The two remaining walls of the workshop are single brick. I am converting the workshop into a cloakroom. A builder has screeded the floor having fitted a shower tray and associated waste under the screed.
Re the single brick walls, his advice was to screw 2x2 wooden battens, fit kinspan insulation board between and then 12.5mm plasterboard on top. He has set the shower tray with these measurements in mind. When I contacted kinspan technical help line for advice on what thickness to use, they recommended leaving a void between the battens and screwing the kingspan in full sheets onto the front of the battens and screwing the plasterboard on top and lag any pipes that are going in the void.
The shower tray in now set too close to the wall for me to do this. I do not want the upheaval of digging up the floor to reset the tray and waste. Any ideas? Advice? Similar experience?
