Dilemma - What should I do?.....
10 Feb 2005
Appreciate all input...
I ordered a Baxi Megalfo System Condensing Boiler (24HE..24kW~80,000 BTUs) over 2 weeks ago. It was delivered yesterday, and the invoice clearly states 24HE but the delivered boiler is a 28HE.
Apart from the moral issue, should I keep it? Will it be more expensive to run than the 24kW model? What are the relevant pros/cons of running the system with the bigger boiler?
The new heating system will have 17 rads and a high recovery cylinder - all BTU calcs were done and the 80,000 btu was deemed to be sufficient.
What would you do?
Henrik
Keep is as i would say 24kw is undersized for 17 rads and a large hot water cylinder....even 28kw is pushing it.
If you are in Denmark then you must consider the local laws and customs and practices.
Advice for the UK may not be appropriate for Denmark.
I agree that a 28 kW boiler will be better but if the property is well insulated then I am sure 24 kW will be adequate.
You only pay for the heat you use so its no more expensive to have a 28 kW boiler.
Tony
Just accept the mistake and if any one says anything you can claim ignorance. Their mistake not yours. It you proceed and pay for it to be fitted they're unlikely to request a used boiler back and give you a new one. If they did, surely they would then have to foot the bill for secondary fitting too.
I'm quite sure they won't bother. I wouldn't worry ;)
Thanks ADWT2004,
Reckon that's what I'll do so.............
Henrik
Agile,
Thanks also......
House is in UK and is being completely renovated, with a particular focus on insulation - kinspan board under suspended timber floors downstairs, insulated plasterboard on all external walls, loft insulated to latest spec, new d/glazed sash windows, so that's why the original calc. came up with 24kW boiler. As long as it's not going to cost extra to run, it's good to have the extra ooomph.....
Henrik
As its a heat only boiler I expect the only difference is the size of gas jets!
I doubt that any other part is different.
Tony
