Is there some reason why 20W 35mm recessed fittings cannot be dimmed? I am hoping to install some tilting units in my living room and wish to go for the cheap and cheerful B&Q option:
these
As the website and packaging tell you nothing useful I had to open one of the boxes and fish out the instructions to find out hole sizes etc, and the first thing on the sheet was 'We do not recommend that you use this product with a dimmer switch'. However the transformer included in the box has 'DIMMABLE' written on the front in large friendly letters.
Am I missing something? I am hoping to operate 6 fittings via the dimmer (2 transformers) so the total wattage would be 120W, well within the limits of most switches.
Also the dimmer switch needs to be 2 gang as it controls 2 standard incandescent mains voltage wall lights as well. Will it be OK to run the MV and LV systems from the same type of dimmer switch? I keep seeing the IQ intelligent dimmers, but don't know whether they would be more suitable in this instance than a standard dimmer.
Thanks in advance for any suggestions.
these
