Installed 10 x downlights into living room. Bought a set of hoods and bulbs from local distributor as follows.
Bulbs are same as ones here :- Have to say not heard of them before.
http://www.lemonbest.com/12w-220v-g...t-for-home-garden-business-lighting-lemonbest
Double dimmer switch from screwfix :-
Varilight Trailing Edge Push Dimmer 2G 1/2W 2 x 250W/VA
http://www.screwfix.com/p/varilight-trailing-edge-push-dimmer-2g-1-2w-2-x-250w-va/98455
6 X downlights on one with 4 x downlight on second.
Did some basic reading on what was required so the V-PRO switch looked ok. All installed and working fine, however cannot dim LED's any lower than about 40% before slight flickering becomes apparent. Read through some posts, lots of ideas on what should/should not be used.
Swich is set to trailing edge.
Any advice would be appreciated, (could it be the bulbs/switch, or do i need to increase load.?) .
Thx JB
Thx JB
