- Joined
- 8 Nov 2003
- Messages
- 2
- Reaction score
- 0
- Country
We had a 2 gang 2 way dimmer. It had been in for 6 months. Then it over heated. I replaced it and the next one did the same. Live went into common, L1 out to 3*40W lamps. Cross wire to common on other switch L1 out to 2*40W lamps. Its the 2 lamp dimmer that burns out, is it because the lamps are only 40W and when the dimmer is less than half on the resistor has too much to do? I've wired it with an ordinary switch and that works fine. It's all abit tight in the box I did wonder if it was just a short? I did also wonder about changing to a switched neutral? Dimmers whilst not being expensive aren't cheap to go through at the rate I'm going through them, anyone got any thoughts? Can I get dimmers that work below 40W?
