- Joined
- 7 Feb 2008
- Messages
- 5
- Reaction score
- 0
- Country
Hi
I'm not brilliant with terminology but will explain to my best ability...
My living room has two wall lights and a centre light.
There was one plate with two rocker switches - one switched the wall lights on and off and the other the ceiling light on and off.
As this was cracked I thought I'd replace it and had a "Dimmer Double 2 Way" handy which I thought would make an ideal replacement/upgrade.
Thinking it would be fairly straight forward I removed the cracked switch.
I've tried fitting the new dimmer a few times so far, with varying success. The first time - both wall and ceiling lights illuminated and the right hand dimmer dimmed them all together. The second - The left dimmer did nothing but the right works beautifully for the ceiling light but the wall lights don't work at all. Etc.
I won't ramble on any more except to say that the back of the dimmer has two of exactly the same units - one 'up' and the other one 'down' next to each other. Both have L1, L2 and a symbol something like a ~ [common i believe].
The available wires in the socket are two reds and one yellow.
Please let me know how should I wire it so one dimmer acts for the wall lights and the other for the ceiling light before the wife drives me mad!!
All the best and many, many thanks for all your expertise
Many :0)
Many :0)
