Hi.
We have an open-plan living area. There are two dimmer switches that operate the kitchen lights: a 3 way dimmer and a 2 way dimmer.
Recently we have noticed that when the kitchen lights are fully turned on they are only half as bright as they used to be, and noticeably less bright than other lighting zones..
We have ensured the switches on both dimmer panels are turned on rotated, so this is not the issue.
We have also noticed that when rotating the dimmer switch in the Kitchen zone, the light disappears halfway through the rotation, unlike the other zone where the dimming happens throughout the dimmer rotation. This happens on both the 3 way and 2 way dimmer panels.
Does this sound like a dimmer switch needs to be replaced? If so, how would I determine if it is the 3 way or the 2 way that is failing?
Thank,
SCGH
Thank,
SCGH
