Dimmer - lights flash off and die
26 Sep 2007
Stirlingshire
Running a 2gang varilight 2x400 model.
1st circuit has 4x50w gu10s and runs fine.
2nd circuit had 8x50x gu10s and works fine most of the time.
On occasion (can be days or a week) when either pressing the button or using the remote to trun on the lights they will automatically dim, if I then try to turn the brightness up they will cut off and mot work till I reset the main power.
I have checked all the wiring and have had the dimmer replaced by the supplier, is the 8x50w=400w too close to the rated 400w for each circuit?
I notice varilight do a 2x600w switch but its twice the size, any one know the size of the modules so they can be swapped with a 400w module?
I have also removed a bulb from the 8 light circuit dropping it back to 350w but still the same?
Any one help me? Its driving me nuts
You have answered your own question
most dimmers need to be de-rated by 50% if using halogen lamps
your first one runs fine becuse its only half the max load (or you could say you have de rated it by 50%)
