Hi all, I recently replaced a BG dimmer that had failed (wouldn't click) with this module, connecting to some LED strips:
Weirdly, it does work, but inconsistently - like 1 in 10 times it will turn on and the dimming works as expected, but even when it does work there's a ~3 second delay. I've tried it on both trailing edge and leading edge but same problem.
Is there anything obvious I should try, or is this dimmer just incompatible with my lights? I've got a similar module (lower wattage) in another room with standard LED spotlights and it works but also has the annoying ~3 second delay. They're relatively expensive dimmers so I'm a bit surprised (and annoyed ).
Very much an amateur so please let me know if there's any further info I can provide. Thank you!
