Dimmer switch very hot??
22 Nov 2005
London
In our lounge we have a dimmer switch to control the main lights - a seven arm 40w chandelier thingy! The dimmer switch has a tendancy to get rather hot, also, if you have the lights dimmed too low they flicker on and off. Any idea on how to cure this, I'm guessing I need to change the switch for a more heavy duty one (if such exists??).
Many thanks,
Screwed!!
If your dimmer unit is an old one it is probably only rated at 250watts & your fitting is drawing 280watts.Suggest you upgrade to a 400w dimmer
Also the dimmer should be derated if you are dimming candle lamps
Ok thanks for the help!! Can you buy de-rated dimmers as a unit or is it an addition to the circuit?? Will B&Q have them?
Thanks again!
de rating example
super duper dimmer rated at 600w for normal lamps
you de rate it to 300 watts as you are using halogens
but 6 months later you chnage halogens to fitting with 500w of lights dimmer will be fine
does this help?
