I'm trying to add dimmer switches to 2 adjoining rooms. Each room has two 2-way switches wired conventionally as follows:
switch2(slave) -> 3 wires -> switch1(master) -> 2 wires -> light
Now its pretty simple to convert this to dimmers by using master and slave dimmer switches.
HOWEVER - between the adjoining rooms is a 2-gang switch containing the master switch for one room, and the slave switch for the other room. Can I buy a two-gang master dimmer switch and convert one of the gangs to a slave? Or will I have to change to 2 single-gang dimmer switches next to each other?
Cheers
Chris
Cheers
Chris
