dimmer switches
10 Apr 2008
Antrim
hi
i recently bought 2 double dimmer switches to fit thinking it would be straight forward as i have done this before but suprise suprise it was anything but. the wiring in my house has 6 red wires which i was expecting but the dimmer switches i bought only have 4 terminals can anyone help
thanks
wrong dimmer take it back
you have a 2 gang 1 way, you want 2 gang 2 way
this assumes you can currently swithc the lights on from here ansd swicth them off from over there (i.e 2 places)
Although there is six wires how many terminals were in use on the old one
A twin one way dimmer could have 6 wires and only use 4 terminals though
If the old one was being used as one way it may have two empty terminals.
yes i agree, but its not the way i read the post from the op
Maybe you are right
But I have never known 4 two way circuits in one house.
Unless he has mistakenly brought one for each end of two circuits
there is allways a first time, but like you say, i bet he has brought one for each end.
jim1000000, 2 normal dimmers on the same cct will not work. they try and interact with each other, you need to have ordainariy switch at one end, OR go for a brand that has master / slave option
