Hope someone can offer some advice....
I have a flat that has 4 EPX Panel Heaters. Unfortunately two of them are not working and out of warranty.
Heater A - If you press the 'on' button nothing happens. If you keep depressed the light flickers slightly. No heat is given.
Heater B - This one will work slightly - but only if the temp gauge is about half way. If you slide nearer to max the heater cuts out.
The other two heaters in the flat work fine. The two that do not work have not been used for some considerable time.
Although there is a programmer system i have not used it (X2D PW4). Given that two of the heaters work and one partially, i do not think this is linked to the problem.
I guess i could do with a pointer as to what the fault may be and whether it could be repairable. Any advice gratefully received!
thanks
thanks
