Dimplex PLX200E - reset PIN?
6 Oct 2013
London
Hi - we have recently had new panel heaters installed in a building at work (Dimplex PLX200E) and some un tech savvy colleague has activated the PIN lock on it and doesn't know how (or hence the PIN) hence the temp can't be adjusted and only "boost" is available. I've checked the manual and no joy. Popping the battery out of the control module resets the date but not the PIN! Any ideas? Thanks.
The default pin is 0000 - 4x zero, if no one has changed it.
If it has been changed, try Factory Reset - Hold 'Enter' down for 5 seconds, then select 'Factory Reset' from the menu.
Hi - thanks. No joy with that. Think he has managed to enter some random pin. Holding downing enter for 5 seconds no effect.
