Hi All,
I've got a little Dimplex XL12N storage heater, it stopped working last week. Looking through some google searches, has pointed me to the fact it has a thermal cut-out switch which could have tripped.
After removing the front cover i have indeed found the thermal cut-out switch, which when pressed "clicked" showing that it had tripped.
Now my only concern is how/why it tripped.
The heater has never been covered so it cannot be that.
The heater was turned up to pretty much max, but it was all last winter too - without an issue.
Now i notice that when i turn the input control around from 0 to its max), it doesn't "click" when it hits the current temperature (i hope you understand what i mean) however the other storage heaters in the house do although none are the same model as this one.
Could the thermal cut-out tripped because the thermostat is broken and therefore its heating up past its maximum? Is this a common fault (cannot find anything that points out that it is)
My concern would be, if i switch it back on at the wall, what will happen, will it super heat itself again? will the cut-out work again? or will it heat up and then burn my house down!
Any comments / suggestions / thoughts much appreciated.
