Diplomat 8702 Washer Dryer - please help
10 Mar 2010
Hello,
Since yesterday my washing machine is giving me a headache.
My wife put quite have blanket and did a wash. The machine was having great difficulties while spinning and washing because it was to heavy.
Then I put just normal laundry and washing machine started to make weird noise while washing- but actually it was washing. The problem started to happen on rise/spin. Washing machine started to get water then started to wash then stopped with loud buzzing noise.
I ve read somewhere to reset the time I need to press key combination but it was quite bad idea as machine died after that. The power still goes to the unit but nothing happens at all.
When I switch it on put the timer for washing the door blocks but the water is not pumped in. When I put on spin nothing happens as well- MACHINE IS DEAD
Please advise what to do - I already took circuit board out and repair centre quote me 60 punds for replacement. I do not want to buy it before I am sure that this is the problem.
I already tried to check the brushes but I cannot locate them and then I found info that motor is brushless.
PLEASE ADVISE WHAT ELSE CAN I DO.
Does it sound like an issue with circuit board or with maybe something wrong.
regards
Martin
have you checked the filter poss bra wire in filter /pump .
