diplomat cooker
31 Oct 2006
Cheshire
hi.
i have a 5 ring twin oven diplomat cooker purchased about 2 year ago. the problem with it is, the cooling fan does never turn off any more even when cooker is cold. Any help would be gratefully received.
thank you in advance
Mark
sorry no ide what so ever.
but since it must come on when hot and go off when cool it must be a stat
I have just changed the fan oven heating element on my DF 1100a DL. There is a thermostat at the top at the back of the fan oven. It is just above the fan cowling. It might be that one. If you heat the oven to say 150'C you should be able to hear the stat click on and off as you slowly turn the oven knob backwards and forwards each side of where you had it while heating. Hope this helps.
Phil
