Diplomat Dishwasher keeps flashing and wont wash
11 Oct 2006
Can anyone help my dishwasher seems to stick on rinse , constantly bleep, and a green light flashes every second. Does anyone have any idea why this keeps happening?
thanks
Nope. No idea at all. Impossible to tell without a model number.
Diplomat machines are made by various manufacturers and rebadged.
Post the model number then we may be able to help.
OK, older model machine. Which lights are flashing and which are solid?
Count from left to right.
the actual start button /far right is flashing. the rinse button is solid green.
You can hold start button down and then you can move the other buttons to go from rinse to say pots however when you shut dishwasher door it starts bleeping and when you open door it has reverted back to rinse, with no water coming out
thanks
Check the model number, it sounds more like an 8322.
If it is count the flashes between pauses on the start button.
Continuous flash without pauses indicates an NTC (temperature sensor) problem.
