direct comination celinder can i pump
10 Apr 2004
i`ve just put in a a direct combination ecom 7 celinder but hot water flow from it is very poor no water at some taps can i fit a pump and if so what type
First get the air locks out. Then decide whether you need a pump. Plenty here if you search.
If you add a pump you need to find out how much cold water storage you have as most pump manufactures will quote a figure of say 25gal cold water storage for the pump to operate corectley
thanks for your help the problem was air once cleared hot water is ok to all tapes no need for a pump : :D
