Direct Cylinder Immersion Issue
T
Tsplumbing
Called out to no hot water fault. 240 at immersion. Tested stat and it failed. Changed stat and heat proof flex (exsisting starting to perish). Job done, or so I thought. Customer called me back and the hot water is only warm (25oc). Any ideas? Immersion element breaking down? Thanks in advance
Was it right length stat ?
Take it you set it to about 60c ?
Was it a cheap brand stat ?
Stat set to 60oc yes. 18" is the correct size too. I’m thinking the element is breaking down because I struggled to get a solid ohms reading across the elements. This would explain the 25oc at the outlets. I’m reluctant to change the complete immersion with it being older than I am and of course they are notorious for ripping the cylinder
