We had a new boiler (Potterton Suprima HE) fitted about 6 weeks ago, and the whole system was powerflushed and had inhibitor added and TRV's fitted etc. When the powerflush was done the water initially came out fairly dirty, but after a couple of hours was flowing clean. (we also have microbore pipes if that is relevant)
Since we had the work done, we have not had the central heating on.
Today we removed a rad in the lounge so we could decorate behind it, and the water that came out was black - it looked worse than when the powerflush started and you literally cannot see through it and there are bits of what appear to be grit in the water. (This rad is on the ground floor)
Is this usual ? I would have expected that as the system had been cleaned and not used since that the water in the rad should be clean.
Has something gone wrong here, or has the powerflush not be done correctly ?
Any thoughts/comments are appreciated..... thanks.
