Hello all
I've moved into a house that has a disabled bath installed (pic attached). The hot water in the bath is fed via a motor, which starts when a button is pressed on the bath and turns off when the hot water tap is closed.
The hot water is fed via the tank (don't know the size) in the airing cupboard and it generally gets cold after 1 bath full.
Since there is already an electrical connection under the bath and a motor, I was thinking of installing a small size jacuzzi (preferably a corner one would look better) in its place.
Would this be a wise idea? What is the smallest size jacuzzi and how much would it cost? Could I re-use any bits from the existing set up? Could I fit the jacuzzi myself (I am fairly good at plumbing and reasonable with electrics)?
I am planning to take the bath out this coming weekend, so please advise if anything needs to be given extra care or if there are some predefined steps of taking out a bath with power shower.
The size of bath is 1500 mm by 100 mm (it is not a corner one at the moment).
Thanks for your replies in advance.
