Disabled toilets have thermostatic mixers on the pipework leading up to the tap. But is the tap unique for a disabled toilet is it any different to a standard basin mixer? If it's faulty does it need to be swapped with another disabled basin mixer tap?
You don't need special taps to work with a blending valve. Assuming the existing poorly tap is a lever type, replacing it with another lever tap is fine. If the levers are the long hospital type you should be able to swap them onto your new standard lever taps
