Hi All
I've got a right mess to sort out at my mum's house where numpty tradesmen have been let loose 'installing' a steam shower cabin: http://www.indigoshowers.co.uk/cabs701sn.htm
Long story short: they've thrown it together and put it in the wrong place, the wrong way around, having not assembled it correctly and not made it square and true. I therefore need to disassemble it, make good the decoration, then put it back together properly.
That should be easy enough, but the cabin has been siliconed at all the joins so is effectively glued together. Each glass panel has an alu frame which slots into a channel in the extruded aluminium corner pillars. These are a fairly tight fit and make contact on three sides, so the silicone in those joins is able to glue the thing together pretty securely!
I've tried just pulling the thing apart but I'm worried about bending the aluminium pillars and nothing is budging anyway. Running a craft knife down the joins to split the silicone on two of the joined sides seems to work to a point but I can only access some of the joins in this way and it's still not coming apart.
Is there some kind of solvent that would dissolve, or at least soften, the silicone to ease disassembly?
Is there a tool like a sash cramp in reverse which could be used to spread the pillars and release them from the glass panels? I'd be worried about damaging the pillars then, but this might be the only way.
I'll see about getting some pics together so you can better understand what I'm up against, but any advice would be welcomed!
