Hi all,
I have an open vent system. For a while we used the heating with the last two of the 6 radiators not working due to needing a bleed but the valves were knackered. As I was bleeding the two radiators by removing the entire hex valve, the expected air rush came but was not followed by any water. Once I had bled both radiators to the same effect, the heating stopped working.
I have checked the ballcock in the F&E isn't stuck, that the boiler fires fine, and the radiators are set correctly. The pump is a Grundfos Selectric 15/50 and when c/h is on it turns, and gets hot, and is fairly noisy. None of the heaters get remotely warm now, which is no fun this time of year. Any suggestions will be very welcome! Thanks in advance
Rich
Rich
