Hello,
I am looking to switch over to a mains pressure from gravity system.
In the room where the cylinder will be sited there is a sink already.
Can the discharge pipe from the cylinders pressure and temperature relief valve be fed into the sinks waste pipe?
If so, can the discharge pipe from the central heating systems saftey relief valve run into the same pipe?
