Hi. Any advice much appreciated. My immersion heater cable ends in a 3 pin plug, and that plug went into a wall socket in the airing cupboard. The socket was old and burnt, clearly there is a problem, whether just a loose connection in plug or not I don't know). I've removed the socket to reveal 2 cables running into the wall. Each cable contains a live, neutral & earth. These then go back to an old style fuseboard.
I don't wish to use the immersion any more. To get enough cable out of the wall to clamp into a junction box to render that end safe will involve a lot of work. So, if I simply remove the 2 live wires where they go into the fuse holder at the fuse board, which will take all of a minute, will this be sufficient to render the circuit dead/safe and enable me to leave the wires exposed in the airing cupboard. Or do I also need to remove the 2 neutral wires where they connect in the fuseboard too (which isn't so easy as they are much harder to get to).
Seems like a simple question, hopefully it is, but I am aware things often aren't as simple as they seem.
