Disconnect Washing machine (Cold Supply Value)
8 Mar 2014
Hi Forum,
I need to disconnect my washing machine (cold supply only) and I noticed that the connection has what seems a small value, whereas I was expecting a blue handle type switch.
View media item 75049
I did try and turn the head with some long-nosed pliers and only managed a quarter turn (if that). I've since sprayed it with WD40. But before I continue, I would appreciate advice if what I'm doing is correct, or if it might be the case that the real value is behind the washing machine - connected to the other end of the hose?
Many Thanks.
Regards
Mark
Many Thanks!
The WD40 seemed to work I gently used some pump pliers to rotate 90 degrees. Given the time of day I will try disconnection tomorrow..
Cheers
Mark
