DISCONNECTED GAS FIRE REMOVAL
4 Oct 2014
Yorkshire
I intend to remove my gas fire which has already been disconnected from the gas supply and all the gas piping under the floor has been disconnected.
My question is: This is a modern house with a cavity flue, do I need to cap off the flue once I have removed the gas fire?
If yes best way to do this and any other things I should consider.
I intend to install an electric fire in its place any issues?
Thanks and regards
Removing the fire still leaves the flue open and this will suck air out of the room and cool it.
But capping the chimney will cause dampness unless a small ventilation opening is left and ideally two, one in the room and one in the loft to allow a small air flow to prevent dampness.
If you cover over the fireplace without capping the chimney then you need to leave a small ventilation opening in the fireplace to allow a small airflow.
Tony
Thanks Tony
I will be installing a simple electric fire in the space and will cover the gas fire opening with a board, I could leave a small vent in that and leave the chimney open?
Gerry
I would suggest about 5 to 10 square centimeters. Obviously round holes would be normal.
Too large and you loose too much heat from the room.
Not enough and you risk dampness.
Tony
Tony
As 112 says, most weeks, when this comes up, new houses are often built with the FP opening boarded over, with no vent. This is with conventional flues as well as precast. To fit a fire, you have to cut the board out. So there is no real need to be concerned about ventilation.
I am only repeating the usual general advice when an open chimney is no longer in use.
Perhaps on those newbuilds it is expected that a fire will be fitted as soon as they are occupied?
Or maybe they are just cutting corners?
Tony
