hi i am moving hoe friday and need to disconnect my gas cooker,i have done this previously .when a relative passted away,all i did was turn the shut of switch turn the pipe and took the cooker,
but just would like to confirm ,is this right to do just turn the leaver as in the picture to off .
then turn the cooker on until all the flame goes out showing no gas is left in the pipe,
turn of the electric main switch then unscrew the 2 screws connected to the wall ,take the cable out .then undo the hose,
what end should i undo the hose the end connected to the wall or the end connected to the cooker,
i am geting a (gas safe) to fit the cooker in the new place,
did i need to do anything else??
when i turn of the lever i will leave it 10 mins and check of the numbers on the face just to make sure no more gas is coming through it
