Disconnecting accent LEDs in ceiling downlighter unit
27 Dec 2011
Brighton
In my flat, I have a pair of ceiling downlighters that have blue accent LEDs that I would like to disconnect.
https://imgur.com/a/z0lK034
In the second picture, they are the four live/neutral cables on the right of the power distribution block.
What is the safe way of going about this - cut the cables, terminate with wago connectors and place inside a junction box? I'm not sure there is enough height for a wagobox light inside the chandelier though.
Or is it best to replace the whole chandelier with something more my preference?
Thanks!
If possible, can you take the unit down and take a better photo of the insides?
The LEDs are extra low voltage, and are the halogen bulbs 12V?
The 'power distribution block' may be a 12V power supply.
With a better pic we should be able to confirm this and if it is 12V, there will be no need for wago's etc. A simple snip of a cable may do! :)
I can't speak for the accent LEDs but the halogen (well, now LEDs) bulbs are 240V GU10s.
But now you mention it, looks like the live/neutral cables on the left of the 'power distribution block' is mains so it could indeed be a 12V power supply...
Ok, taking it down should give you a better idea :)
If you are lucky, the supply for the power supply may come directly from the terminal block and you only need to undo that connection!
