I have an Indesit WG1030 which I need to run off an inverter. It works OK on the inverter except that the heating element pulls too much power.
Is it possible to disconnect the heater in such a way that the machine 'thinks' the water is warm (I can live with cool washes)?
I would just disconnect the element except that the machine waits for the water to warm up.
On the back of the drum, near the bottom There are two white rectangular objects (one with 3 wires (one of which is connected to the 'neutral' of the element), one with 4wires). I assume they are the thermostats? Can anyone sugest how I can fool it into thinking the water is warm?
The machine has more than one temperature setting (40, 60, etc), but the only temp setting I need to disable is the 40°C one (I don't use the hotter programs).
Mab
Mab
