Disconneting a sink - T-piece capping
20 Feb 2006
I want to remove a wash-basin in a room adjacent to the bathroom. On inspection, it turns out that the hot and cold are fed from the supplies going to the bathroom sink. They branch off using T-pieces and there is an isolation valve on each . Diagram below (hopefully it makes sense). All of this plumbing is in the bathroom with only the pipes going through to the spare room.
| ===<VALVE>===SINK
What is the best way of disconnecting the sink? The easiest way would seem to be to cap off after the isolation valve, but I don't know if an unused spur is a bad idea.
Thanks.
Just close the iso valves and undo the fittings downstream. Simple.
Thanks. Is there a chance this could cause a dead end though, allowing the water collected there to stagnate?
Yes, but if it's a short dead-end it's nothing to worry about. I'd only be remotely concerned at a dead-end of more than a couple of metres.
If hidden, connect a short peice of copper pipe witha push fit stop end on it to the isolation valve. If accidently opened or fiddled with by a child, then the pipes will not leak water.
