Help!
My Disco's V8 has turned into a fuel pump.
It startered running lumpy at low revs, woudn't pick up from tick-over very well and started to stall now and again - it also had a slight misfire at around 2,000-2,500 revs.
Its been to a 4x4 specialist and put on, what looked like to me, a very basic diagnostic tester.
They first thought it was the Lambda probes (strangely, even the though the test showed and imbalance between the sensors - one bouncing around 15 the other around 7) they said that they'ed tested the sensors and they were OK.
Next, at a shade under £400 they reckoned it could be the Airflow meter, a quick change out made no difference.
All else is OK, and the problem came on suddenly, like something let go.
If you can get it to start, and when it does, it tends to be first time, it can run quite well, especially if given a run - but not always!.
If it doesn't start first time, the overfuelling just make things worse, and you can't guarantee then if it will start at all.
I'm now facing taking to LR, as I reckon they might have a more comprehensive diagnostic test than this 'specialist' I've just been to.
But before I do, I thought I'd throw this one out there to the combined minds of the forum.
Cheers, and fingers crossed,
Ian
Ian
