- Joined
- 25 Jun 2015
- Messages
- 60
- Reaction score
- 0
- Country
Hopefully I'm posting this in the right area? Anyway, I'm looking to install some decking boards on a balcony I have. The boards are not the standard ridged boards you see a lot of, but a smooth hardwood board (Balau, I think its called).
I was wanting to have a discrete fixing system that the supplier of the boards supplies. However, they do not recommend it for these boards due to the type of wood and the amount of movement that the boards will have.
I don't want to screw the boards through the top as I would end up seeing hundreds of screws along the length of the deck, in which case its pointless spending the extra for the hardwood board.
So doing some digging on the net brings up a 'Kreg' Jig. This looks the part and would probably do what I'm needing. But at nearly £70 its not cheap! Are there any alternatives you could recommend? Or is this the way to go? Also, what Screws (zinc / Stainless Steel etc) would you advise?
Many Thanks in advance
