Hi All.
I'm new to the forum and this is my first proper post so please try to answer in words of one syllable or less.
I am installing 2.5mm SWA out to the garage to a small CU with RCD containing a 16A and a 6A MCB covering sockets and lights.
The 2.5mm SWA can carry enough current to feed anything I am likely to use for now (fridge and one power tool at a time and a couple of 35W fluorescent tubes) and it came at a very good price so I don't particularly want to install bigger cable at a higher price.
At the house end of the SWA it will be protected by a 20A MCB. There is no other load on the 20A MCB and the SWA feeds only the garage CU. I propose to put it on the RCD side of the house CU.
My question is - Should I care that there will not be discrimination between the 20A MCB in the house and the 16A MCB in the garage?
In other words am I right in thinking it is a matter of inconvenience rather than safety that the 20A could trip if there were a fault on the garage sockets?
