O.k., i got all the residue off the spindles, and it turns a bit more, but I dont know where to find the filter to clean it out to see if it is reducing the water pressure. anyone know where to look for the filter?
Try soaking the entire moveable arm in an anti-limescale solution, ( here in the UK we have Calgon or Viakal.) Let it soak for a while and this should not only help the arm to move better but will clean out the exit holes and help the water pressure too.
