Dishwasher CDA model CW497
28 Feb 2004
I have fault F7. I have taken side panel off and replaced micro reed switch. The old switch was not operating (checked with digital meter and magnet). New switch operates fine (normally open and closes when magnet is used). The new switch is from Maplins and was recommended by someone on the internet.
I still have fault F7.
I cannot find the description of the actual switch and therefore may have put in a switch that is not compatable.
The water chamber is partially discoloured - could that be a problem ? I don't know how to remove the chamber to check/clean it.
Water does enter the chamber at the start of the cycle and the pressure seems fine but after approx 10 seconds the bleeping starts.
Any help would be appreciated.
Steve
