Dishwasher help (Bosch)
29 Jul 2007
Northamptonshire
Hi, I have a Bosch Logixx Dishwasher (SGS66A02GB/17) which doesnt seem to be working correctly. It basically makes a whirring noise (which I assume is the pump) but is not actually spraying water inside. The water hose is all working and the tap is on(!) and when you start the cycle it whirrs, the time remaining stays at 117 minutes (or whatever cycle you choose) and it carries on whirring until switched off.
Occasionally it will work (maybe once every 3 days) but will always stop at 1 minute remaining (never finishes the cycle) and continues whirring again until switched off. Tried resetting it but this just changes the time remaining to 0 and does nothing else. Is there any fault codes or a means of diagnosing the problem, or a way to reset the dishwasher completely, rather than just the cycle?.
Could it be an airlock or the flood sensor? There doesnt seem to be much water in the base though?
Any help would be fantastic
Chris
Ive discovered that if I bang the dishwasher quite hard it seems to allow it to work fine. Would this mean that the flood switch is jammed and the bang is releasing it?
Hi cjjowett
Can't help with your problem except to say the float switch sounds logical.
Just writing to say I have exactly the same fault, have undone a few screws and looked around but nothing seems blocked or broken.
Wondered if you resolved the problem before I resort to the repair man.
Regards
