Dishwasher not draining.
3 Oct 2009
Kent
I have a zanussi DA 6141 diswasher.Where are all the filter points for cleaning? The bottom washer reevoir isn't emptying so I am trying to find out how to unblock it .Thanks
Possible pump or pipe blockage
Does the drain pump run when you switch the machine on initially (The pump should run for a short while before it takes in water)
Check your waste hose for a blockage especially if it goes to a spigot type waste connector instead of a down pipe.
