dishwasher problem
9 Jan 2005
The tablet either drops out, a little mushy, or remains in the tablet container, barely touched.
There seems to be plenty of water getting through.
Did you manage to recolve your problem and if so, do you know what the cause was?
Thanks, Elaine.
_______________________
Moderator
split from hi-jacked post
if you all post make & model numbers i will do my best to help you out
most of the time the machines are blocked or its the main pump. but do need model numbers to help.
ok the main problem with this is blocked spray arms or something stopping them turning. the only other thing i can think of is the main pump. but i dout it very much.
are the filters blocked with greese? scrub in hot water.
hope this helps..
