Dishwasher traps...
22 Aug 2005
Newcastle upon Tyne
Morning folks,
Need to assemble a u-bend trap for a slimline dishwasher in 32mm pipe. Trouble is I can't find anywhere local that does traps in 32mm - only 40mm (the hole to the outside and the drain is only big enough to fit a 32 :( ) Can I get away with using right angle compression fittings (or push-fits - although I'd prefer compressions for peace of mind) - or is it not advisable to have water sitting in a u bend that isn't a one-piece fitting?
Ta muchly
All modern basins are 32mm, every DIY shed in the country (that I know of and assuming your in the UK) sells them. No problem in making your own, but why bother. Where have you looked ?
you could use an hepV0 trap with an adaptor
B&Q-shed, wicks-shed and even *shudder* homebase-shed - nowt in terms of washing machine / dishwasher specific traps in 32mm (all 40mm) - guess I can adapt a normal sink trap or something. Just I had some spare right angle compression joints easily available and couldn't be bothered trawling round the local places when I could knock something up which wouldn't come back and cause problems later - I'll doa double check tonight and if nowts about I'll go with a home made job ;)
No prob making your own trap from 90 degree bends, providing it can be dismantled for cleaning (well probably unnecessary for dishwasher!) and is well supported. But do you realise you can also connect dishwasher waste into existing sink trap, etc?
you can use any old 32mm trap with a 32mm to male Iron coupler, from any GOOD plumbers. It'll be made of plastic. Trap one side and pipe the other.
I did, But sadly the dishwasher was / is on the far side of a support column to the sink (due to the wacky but functional layout / shape of the room we've got), and while I've boshed the water pipes through the column I was more reluctant to put a hole through the column the other way for waste. In the end I used a 40mm washing machine trap from wicks, managed to "persuade" a 40mm pipe through the outside wall and ran it to the drain - bit of a tight fit but got there in the end.... And the beauty of it all is the pipe didn't crack while I was persuading it through :D
*Happy days*
But it might crack later! The pipe will expand and contract with heat, resulting in small movements which will rub the pipe against masonry, eventually wearing a hole, perhaps. Just a comforting thought.:evil:
