- Joined
- 24 Apr 2021
- Messages
- 1
- Reaction score
- 0
- Country
Hi
I have a Bosch dishwasher that does not go into the higher pressure rinse cycle.
It fills and I can get it to drain, the motor spins and all of the pipe system is clean, filters and impeller and sprinkler sections clean. I have dismantled and cleaned everything. TBH there was little to clean.
You start a cycle and all seems fine until it should switch to spraying water.. I can hear the pump working / motor but not as vigorously as I would expect. when I open the door I can see water is flowing out of propeller rinse arms, but only at low pressure!
any ideas welcome before placing an order for a new one.
