Problem with Dishwasher Whirlpool ADG 957, 16 years old.
When i launch a program (any program, from rinse to 70° cycle, it's the same), i press start, i close the door, the dishwasher makes some sounds like the pump is working, and it immediately starts beeping (alternate beeps), then the sounds of the pump stops, the beeping continues, i open the door, the beeping stops, the first light (rinse) is on and the light above the start button flashes (continue flashes, it never stops).
So i reset the process by keeping the start button pressed, and i go on to perform the diagnostic test, like this:
- set the program on rinse
- turn off the machine
- while keeping the start button pressed, i turn the machine on, i keep the start button pressed until the light above the start button flashes, then i close the door and the diagnostic tests commences, no beeping sounds, just the machine working and i hear the pump working making the usual normal sounds.
After a very short time (not the full 20 minutes diagnostic, much less, maybe 5 minutes) the sounds stop all together, i open the door and i see the third light (eco bio 50°) flashing, which i suppose is the test code, but i dont know the meaning.
Does anybody know what the meaning is and if i can fix the problem myself?
Thanks in advance.
Thanks in advance.
