Which is apparently drainage...except it seems to drain fine.
Diagnostic turn-off,hold-start-button,turn-on,press-button-when-flashes comes up with four flashes.
Stuff I've tried so far:
bowl of water in the bottom drains fine.
Kettle full of boiling water in the sump, drained fine.
Took out the sump pressure switch, cleaned and tested. Outer pins connect/disconnect when membrane is pressed, so I guess that's ok?
How do I identify/test the OWI thing or water indicator?
